• Axial Yeti Score Trophy Truck RTR kit
      Axial have introduced the 1/10th scale Yeti Score Trophy Truck. Based off of the Yeti rock racer the RTR truck features an independent front end suspension and 4-link solid rear axle package for a unique look and on-track performance. Aluminium oil-filled shock absorbers soak up surface imperfections while BFGoodrich Baja T/A tyres on Method 105 replica wheels make for forward traction of the 4WD vehicle. Equipped with a 3150kv brushless motor and a waterproof 3S-compatible speed controller the truck also features a lot of officially licensed accessories for scale looks while the included 2.4GHz radio system allows for best possible control of the 1/10th scale vehicle. The truck is rounded out by a pre-painted bodyshell with roll cage and spare wheel.
      Features:
      – 2.2/3.0 BFGoodrich Baja T/A KR2 tires (SB40 compound)
      – 2.2/3.0 Method 105 replica wheels
      – King aluminium shock bodies
      – AR60 OCP-AXLE. Solid rear axle, 4-linked with multiple tuning options
      – Rear sway bar for added stability at high speeds
      – Includes moulded plastic light buckets at all 4 corners. Simply add our LED lights and controller for a street legal pre-runner.
      – Hi-lo transmission with optional 2-speed components available (AX31181)
      – Fully functional spare wheel and tire with a quick release mount and swing up restraint
      – 3150kv brushless motor
      – Vanguard ESC, 3S LiPo capable, waterproof
      – Tactic TTX300 3-channel SLT radio
      – Tactic TR325 3-channel, 2.4GHz receiver
      – Tactic TSX45 metal gear servo, 151 oz-in, water resistant
      – Dual slipper clutch
      Kaynak : redrc.net
      Bu makale başlangıçta forumdaki konuda yayımlandı: Axial Yeti Score Trophy Truck RTR kit başlatan yazar 100kmh2sn Orijinal mesajı görüntüle
