Phoenix TIGER 3
  •  » Konudaki mesaj sayısı : 3
Toplam 3 adet sonuctan sayfa basi 1 ile 3 arasi kadar sonuc gösteriliyor
    Phoenix Tiger 3
    Gonderilmez elden teslim edilebilir. Urun izmirde.
    Govde, ana kanat, rudder ve elevator toplanmis durumdadir, Servolari (metal disli ve bu model icin uygun) uzerindedir.
    Yer degisikligi nedeniyle tamamlayamadim ve tasiyamiyorum.
    Yaninda 2. el bir MAgnum XLS motor hediye verilecektir. Calisip calismadigini eksigi olup olmadigini bilmiyorum.
    850 TL
    FEATURES
    Construction: All balsa and plywood
    Wing: Bolt-on two-piece with aluminum joiner tube
    Covering: High quality heat shrink covering, color scheme is white
    and red with dark and light blue accents
    Canopy: Clear, painted pilot bust
    Engine Mount: Two-piece composite plastic
    Motor Mount: Plywood
    Spinner: Red plastic 2.3 (58mm)
    Landing Gear: Main-prebent wire, nose gear-steerable prebent wire
    with three 2.5 (63.5mm) treaded wheels
    Fuel Tank: Approximately 12oz (354cc)
    INCLUDES
    ARF Tiger 3 Aerobatic Airplane with Fuel Tank, Motor Mount, Engine
    Mount, Landing Gear, Spinner, Pilot Bust and Instructions
    REQUIREMENTS
    Radio: 4-channel with five servos
    Glow Power
    Engine: .46-.55 cu in (7.5-9.0cc) 2-stroke
    .52-.61 cu in (8.5cc) 4-stroke
    Receiver Battery: 4.8-6V 800-1200mAh NiMH
    Glow fuel, prop, glow starter
    Electric Power
    Brushless Motor: 1000-1400 W, at least 480 KV
    ESC: 50-70A brushless compatible
    Battery: 4000-5000mAh LiPo battery
    Battery Charger: Compatible with selected battery
    Prop to match selected motor
    Building and field equipment
    SPECIFICATIONS
    Wingspan: 63 (1600 mm)
    Length: 53.5 (1360mm)
    Flying Weight: 5.5 - 5.9lbs (2500 - 2700g)
    Wing Area: 662 sqin (42.8 sqdm)
    Wing Loading: 19.66ozsq ft (60g sqdm)
    Airfoil: NACA
    Center of Gravity: 2.9 - 3.3 (75 - 85mm) back from the leading edge
    of the wing at the fuselage
    Control Throws
    Ailerons: Low: 8mm updown, 10 expo
    High: 10mm updown, 10 expo
    Elevators: Low: 8mm updown, 12 expo
    High: 10mm updown, 12 expo
    Rudder: Low: 25mm rightleft, 12 expo
    High: 40mm rightleft, 15 expo
    • Dosya tipi: jpg daginik.JPG (52,4 KB (Kilobyte), 13x kez indirilmiştir)
    Hala satılık mı?
    Saygı olmazsa sevgi de olmaz ....
  1. Phoenix Tiger 40-46 Hakkında Merak Ettiklerim?
    Konu Sahibi Tamer Öztürk Forum Spor, Akrobasi, 3D Modeller
    Son Mesaj : 09-05-2014, 19:35
  2. Phoenix Run phoenix diyorum fakat simulator acılmıyor yardım lutfen
    Konu Sahibi forkill96 Forum Simülatörler ve Diğer Yazılımlar
    Cevap: 4
    Son Mesaj : 30-11-2011, 13:36
  3. Phoenix Run phoenix diyorum fakat simulator acılmıyor yardım lutfen
    Cevap: 4
  4. wing tiger aldım (buradaki yorumlara dayanarak wing tiger aldım):D
    Konu Sahibi kesik Forum Üstten Kanatlı (Eğitim) Modeller
    Cevap: 6
    Son Mesaj : 03-07-2011, 18:16
  5. Phoenix Su-31 ARF
    Konu Sahibi aozgen Forum Ölçekli Modeller
    Cevap: 22
    Son Mesaj : 30-08-2008, 20:10
