SkyRC introduce the Ultimate 1000W DC multi-chemistry charger for the use with up to 8S LiPo or 20 cell NiMH battery packs. The high-output charger offers up to 40A of charge current at 11V to 30V input, allowing to super-swiftly charge 4S to 6S battery packs for 1/8th and 1/5th scale vehicles. A special LiHV mode for new generation Lithium-Polymer batteries lets the user enable a cell end voltage of 4.35V while the charge end voltage for standard LiXX batteries is user adjustable. The balance charger features 10 charge and discharge profiles, several cell monitor functions such as an internal resistance test as well as the usual range of safety features. All charge parameters can additionally be monitored using SkyRC’s Charge Master software that also helps to update the firmware, and the charger is furthermore remote controllable using the company’s optional Wi-Fi Module and an iOS or Android mobile device.
Specifications:
– Dimensions: 138x156x76mm
– Weight: 1240g
– Output: 1-8S LiXX, 1-20 cell NiXX & 2V-24V Pb
– Input: 11-30VAC
– Charge circuit power: 1000W
– Charge current: 40A max.
– Balance charge current: 10-500mA
– Discharge circuit power: 80W
– Discharge current: 0.1-40A
Kaynak : redrc.net
